Cleveland Apprentice
- Cleveland, Oh
I am not familiar with Square D products and called a couple suppliers looking for a 3 pole, 80 amp Square D QO style breaker bolt on. The CB must be straight rated at 240 volts as this will be used on a 240 3ph Delta service. A couple suppliers I called didn't know what straight/slash rating meant so I had to explain. I told them my concern of the high leg to ground (208 volts) which was reason for straight rating. They still seemed a little confused. Anyone experienced anything like this with supply houses?
Also, I checked online for the above CB which has the identifying code as QOB380. I saw two different websites with same breaker code. They were at least $200 cost difference (both 10K aic) which adds up big if need several. Looking at the photos of both on websites, they have 240 stamped on it but not the lower 120 value. I assumed this was the straight rated and contacted the distributor online to make sure. Their response was that the QOB380 is slash rated. Now I'm confused and doubting them. I would think if it was slash rated then the lower value number of 120 would be required to be stamped on it. Thanks for replies in advance and have a Happy Easter!
