jumper
- 3 Hr 2 Min from Winged Horses
Because the fingers of the busbar are only rated for 100/125amps
Check the size of the lugs.
The 4-pole one looks like it is intended for parallel conductors.
The smaller one is typically factory installed, with specially bent wire from the load side of the meter. The other two appear to be user installed main breakers for panels that didn't have a factory main.
