- Tennessee NEC:2017
- Semi-Retired Electrician
Does anyone know if a Sq D Homeline 200A load center has the same amount of breaker spaces as there is K.O. tabs for the breakers?
In some panels it appears that there are two spaces left at the bottom, across from each other, but when you take the cover off the bus bar doesn't go down that far and there are no more spaces.
I'm trying to look at a job via pictures sent because the job is a good distance from me and I don't want to drive that far just to look.
