Thank you.Loadcenters can be used anywhere. They are not as robust as panelboards, but are used frequently in three phase applications too.
I know what you meant but just to clarify, I don't believe Homeline makes a 3-phase panel.Loadcenters can be used anywhere. They are not as robust as panelboards, but are used frequently in three phase applications too.
Yeah, I don’t think I’ve seen a Homeline three phase loadcenter, but others do make them.I know what you meant but just to clarify, I don't believe Homeline makes a 3-phase panel.![]()
Confirming: Homeline is not offered in 3 phase.Yeah, I don’t think I’ve seen a Homeline three phase loadcenter, but others do make them.
You can get a QO plug-in 3 phase load center.
I would recommend to OP to verify breaker availability if using a QO. I’ve had a lot of trouble getting QO breakers. QOB’s seem readily available except for GFCI’s.
Eaton offers BR and CH in 3-phase. I think GE does also.
I believe that is true, but one could still utilize series ratings to get at least a 22kaic rating. Maybe higher, but I haven't looked at the sq D series rating charts in a while.Another consideration is if you need to meet a higher AIC rating, the HOM breakers I've only seen available in the 10Kaic rating, so if you need more like a 22 or 65 you might consider something else like the QO model.
