jmellc
- Durham, NC
- Facility Maintenance Tech. Licensed Electrician
Partner went to Big Orange for a panel for a night job. Got a Homeline. It had the built in cable slot connectors all through the top and bottom. Only 4 combo ko's to use for anything else. Maybe not so bad if using it new, but we were reconnecting cables brought down a plywood wall in a certain order, many too short to move much. This panel requires the 14's in one section, 12's in another and only a few slots at all for 10's.
Our local Square D dealer has a QO panel on display with same stuff. If standard panel cans get too hard to find, I will ditch Square D as much as I can. I've always liked the brand above all others but they are really irritating me with such junk as this. Before this, it was the Homeline direct stab AFCI breakers. Several times, I had to order standard ones with a pigtail. I've never gotten over my anger with AFCI's to start with and didn't need the new ones shoved down my throat.
I may start using BR as my standard first choice. Much better than GE, some better than Siemens, reasonably priced and usually available.
