SquareD Panel
Has anyone ever heard of a SquareD Trilliant Service Panel? I have never seen one. It is no longer manufactured. A customer would like a circuit added for a Hot Tub.
What can I do besides replace the entire panel?
Thanks,
Joseph Savastano
charlie
Indianapolis
Re: SquareD Panel
Trilliant was a great idea before the siding contractors started driving nails into the bus. :eek: The pan was plastic and would not stop a nail very well.
To answer your question, you may add a circuit. The panel was listed when it was manufactured and installed. I don't know if it uses a QO breaker or something else. You may have a problem getting a breaker for it that is listed for the panelboard.
jim dungar
Wisconsin
PE (Retired) - Power Systems
Re: SquareD Panel
Some Trilliant breakers are still available from Square D through any of their full-line distributors. The selection will grow smaller as inventory is sold.
List price for a #SDT245 (45A 2 Pole) is $91.00.
They only have GFI breakers in 15 & 20A single pole.
goldstar
New Jersey
Electrical Contractor
Re: SquareD Panel
Try this company :
ARCK Electrical Supply
1875 Barrett Drive
Rockledge, FL 32955
(800-856-9756)
e-mail : arckelectric@earthlink.net
I had an occasion last year to add a sub panel to a residence with a Trilliant panel and the largest 2-pole breaker they had was 40 amp. Hope this helps. Good luck
lrollo
Re: SquareD Panel
If you dont find a breaker elsewhere, I hear www.breakerbrokers.com is a good place to go. I got the pleasure of buying a 150 Amp 2 Pole Zinsco Breaker there about a month ago.
[ September 02, 2003, 09:12 PM: Message edited by: lrollo ]
ctkern
Re: SquareD Panel
Try your local distributor and see if Connecticut Electric Sweitch makes that breaker. They manufacture replacement circuit breakers for nearly all "extinct" residential panels (Federal, Zinsco, Pushmatic, etc.) . (UL listed).
