hardworker
If a panel has a main breaker on the same stab as a breaker that is feeding a load, do you consider the main breaker ampage as part of the equation.
Slot #1 and #3 have a breaker for 70 amps and across from it on #2 and #4 the main breaker is a 100amp. If the stab maximum rating is 150 amps is there a problem? One is a load and the other is a line. Does this make a difference?
