bejoyeleengineer
We generally provide a Stabilising Resistor in a High Impedance Type REF Protection Scheme, to de-sensitise the relay from operating from through fault conditions - in case a CT Saturates. This resistor is calculated such that under an external fault condition (that is for full fault level), the voltage developed by the un-saturated CT shall not circulate more current than the setting in the relay - thus preventing the relay from oper\ating for an external fault.
Now, my doubt is, will the relay not be de-senisistised upto this full fault level, even during an internal fault? Normally for an internal fault, the magnitude of the fault current would be much lesser than a full external fault. But, by providing the resistor, we have already de-sensitised the relay from operating even for a full fault current. How then, the relay gets sufficient current even after the resistor, during an internal fault?
