Stabiloy MC Cable run in shaft
joela
New member
I am intending to run Stabiloy MC Cable (Aluminum) Feeders in the same vertical riser shaft as a 16" diam Boiler flue, some plumbing pipes and HVAC duct. The size of the shaft is 7'-0" x 3'-0". Can this be run together in the same shaft, or is a separate shaft or barrier required for the Aluminum Feeders?
