marmathsen
- Seattle, Washington ...ish
- Electrical Contractor
In Seattle I have seen many installations where a new surface mounted meter has been installed over top of another one with the service conductors running through the old meter into the panel. In the occasions where I have removed them, there are no splices or connections inside the old meter. I've held the opinion that this installation wouldn't be allow by code but I've seen it so many times that I wonder if I'm mistaken. I'm looking at a repair project right now with this type of installation. If I replace the meter, then the underground laterals and conduit need to replaced out to the street (a big project).
What's your opinion on this type of installation? Do you feel it's legal? Is there specific code that justifies this as an approved type of installation?
My thinking is that the meter in the back isn't designed for this. Water proofing seems like it becomes an issue. On the other side though, without any connections in the back side enclosure, maybe there is no need for access into it. Yet we need access into conduit bodies with no connections.
Rob G
Rob G
