Electron_Sam78
- Palm Bay, FL
I'm wiring lights for a church stage and auditorium but they need to be run to a stage lighting control center that uses dimmer packs such as the one here: http://www.mbtlighting.com/product-details.cfm?ProductID=4685&CFID=47417809&CFTOKEN=90321785
I also need to supply power to the dimmer packs.
I've never dealt with stage lighting controls before. Do I need to size my supply wire for the max load of each dimmer pack used (15amps on the example website above) or only provide for the load that is being installed - the total of all my lighting? There will be enough dimmer packs to cover all the lighting load but some packs will not be used at full capacity since the lighting needs to be spread out over several channels. So if the rack has 4 dimmer packs with each at a max of 15 amps should I size my wire for 60 amps or go with the actual load of the installed lighting which would be around 35 amps?
