RJJ
- Houston, Texas
Hi everyone, I recently came across this particular product installed inside an enclosure (https://r-stahl.com/en/global/produ...s/control-devices/resistor-series-8453-49633/). The one that I saw has a 1N4005 diode fitted inside of it and is used as a blocking diode to prevent current backflow (24VDC circuit). After being installed, the unit with diode works for a while and prevents current backflow as intended. But after some time, it shorts out and does not block the backflow.
I was initially thinking that it could be that the 1N4005 is a 1A diode and that maybe a higher current could have flown through it leading it to failure. However, I am not sure if this the reason. Stahl makes a similar unit with a SB550 diode inside, which is a 5A diode. Do you think that would help? Any thoughts?
-RJ
-RJ
