I am having a problem with an inspector. The home owner wanted to install a generator for their entire home. The service consists of an existing 400 amp K7 meter can. From the meter can it nipples to the gutter. There are three disconnects, below the gutter, feeding the existing load inside the home. We installed the transfer switch on the right hand side of the gutter and we fed from the transfer switch to the generator and back to the gutter to feed the existing disconnect for the generator. The inspector is calling for a main disconnect for the entire service. My question is do I need a Main Disconnect or am i in code with article 230-71
