I had a discussion with other engineers regarding if we are required to provide a separate transfer switch for the inverter system. The current design shown to have two separate transfer switch one for standby loads and the other is for emergency lighting. We have decided to add an inverter system which is a stand alone system and does not depends on the generator if it runs or not. my thought, since this is a stand alone system and it won't be affected by the generator, we can feed it from the standby switchboard (or distribution panel) and we can delete the life safety emergency transfer switch and associated panel. Is this a code violation? or we can feed the inverter from the standby panel since it stand alone emergency system? Any thoughts.....Thanks in advance
