curt swartz
Electrical Contractor - San Jose, CA
- San Jose, CA
- Electrical Contractor
I am working on a project to install a back up generator for a single family dwelling. Because of my schedule and this Town?s requirements I have asked an electrical engineer to help me with the required drawings. I was planning to use a 30KW generator which is the largest one permitted with out going through an expensive environmental study. My electrical engineer feels that the generator needs to be sized according to the maximum calculated load that could be connected to it. I have always sized these backup generators based on what loads the customer would like to be able to run during an outage. I have installed and seen many generators installed that are substantially smaller than the actual calculated load. Frequently a 200 amp transfer switch gets installed in series with the 200 amp main feeder but a 15 KW back up generator is used. 702.5 requires an optional standby system to have the capacity to supply all required equipment intended to be operated at one time. It also says that the user of the optional required standby system shall be permitted to select the load connected to the system. Since this is not a required system I feel if the home owner decided to turn on every light in the house, do laundry and turn on every other load they think of causing an overload on the generator it would simply cause the overcurrent protection generator to open. I frequently see transfer switches that have the generator side of the switch rated less than the primary supply. If the generator is required to be sized according to the maximum possible load on the switch I don?t see any use for this type of switch. Let me know what you think.
Curt
Curt
