Greeting all, this is my first post to the forum, and perhaps someone here can help me with a generator sizing question. I am trying to size a stanby generator for a facility that contains some devices the require startup current (RLA). After doing the calcs based on motor code specs, I find that the generator size that is required is larger than the utility service transformer. Is it true that if given an equally sized generator and transformer, that the electrical stress to the windings would be different? Or is the generator more stressed because its output is driven by an engine(which can droop when loaded) vs commercial power that is not hampered by the loads of one facility. Thank you for any insight that can be provided.
Tank
Tank
