Im working on sizing a standby generator for a home with geothermal. The compressor unit or heat pump says is draws 44.8 amps at 240v. So that is 10,752 watts. The auxiliary heat in the unit is 9.6kw so total with them two alone is 20,352 watts. My question is when auxiliary heat kicks on in these geothermal units does the heat pump still run while the auxiliary heat is on or are they separate from one another? This will obviously affect my generator sizing significantly, never really dealt with geo thermal units so not sure how to size this
