I was wondering if anyone can guide me in the right direction, I installed a 17KW Generac Guardian Series generator along with a 16 circuit prewired ATS, After install and programing of genertor when putting generator in the automatic position it reads utility loss, I check all terminals in ATS and in generator I have all the correct voltage except on N1 I read around 60 volts Generac said to replace the N1 and N2 wires from ATS to generator and this will clear up utility loss I did just that and I still have the same reading, I had a tech come out and change out board in generator and still it reads utility loss, as we all know the generator will run all the time in the auto mode with this reading, what should I do next.
Thanks
Thanks
