Hi
I am planning to install a standby GEN SET of 60 KW at a pumping facility. The utility feeds the electrical panelboard. The utility has 3phase, 3wire system, 480v. They do not plan to upgrade this to 3phase/4wire at this time. If I use a 3 POLE TRANSFER SWITCH, and DO NOT ground the GEN SET neutral, and leave it at 3PHASE, 3WIRE system, WILL I VIOLATE THE CODE? The load is just motor loads.
thanks
murli
thanks
murli
