Bogiedown170
- Yonkers, NY, USA
Just came across an area that is designated as a flood zone. The generator is bolted to a metal stand that is about 3ft tall on concrete base. As I’m trying to get up to speed with 2020 code, I was wondering if it is necessary for the generator to be bonded to the metal frame? Under normal installation, I understand that no grounding rod is necessary, but with the metal frame, is bonding to frame required and or ground rod? Thanks to provide any insight.
