Gerry_G
- Massachusetts, USA
- Electrical Engineer (retired)
Starlink Services (rural, VERY HIGH SPEED, satellite internet, in the US and 17+ other countries so far) only supplies a phased array antenna dish with a custom 100' shielded Ethernet cable permanently attached. The antennas are usually mounted high, on a high mast or tower. The antenna is very uniquely, not what most are accustomed to with satellite internet. The phased array needs a fairly wide view of the sky since the satellites are not stationary and the phased array switches what satellite it "talks to" very frequently. The custom cable also needs to supply ~100 W to the antenna. Standard Ethernet cable can't handle that power level @ 56 V.
They only support running that cable into a building with no lightning protection, not even grounding/bonding the shield at the building entrance. There are reports of lightning strikes destroying (literally blowing apart) the power supply inside the house and disintegrating the custom cable to the antenna. The only "ground" is inside the building at the power injector. The only ground is via the 3 prong 15 A power supply cord.
This appears to be very dangerous, folks are mounting the antennas high, thus prone to attracting lightning.
Their minimal FAQ https://www.starlink.com/faq contains:
"Starlink meets the U.S. National Electrical Code (NEC) grounding requirements and includes the necessary lightning protection. However, any user who lives in an area with lightning should have the appropriate lightning protection installed in accordance with your local electrical code prior to using Starlink." (bold my emphasis).
However, their support replies to never cut the or extend the supplied cable, thus one can't even ground the shield at the building entrance. Also, being non standard cable, one can't even use an available CAT 5e/6 protection unit at the building entrance.
I don't believe Starlink's configuration meets the NEC re lighting protection.
Am I correct, if so, any suggestions?
