texie
- Fort Collins, Colorado
- Electrician, Contractor, Inspector
Customer bought a used 10 HP 3 phase sawdust collector. As per usual they don't understand the details. Unit factory wired for for 480 volt with an IEC starter. Need to convert to 208 and get a NEMA size 2 starter as the existing starter will now be to small. I noted that the motor is inverter rated and since the customer also does not understand air flow either and I don't know the details on the ducting I'm wondering if it might be just a easy to just use a VFD so he can adjust as needed. Thoughts?
