friebel
- Pennsville, N.J.
There has been a thread relating to the proper procedure for handling of loading and unloading of a railcar with a hazardous materials.
I have stated that you should have all equipment, piping, etc. bonded all together and I would want to see zero ohms for continuity with this bonding.
After we have bonded all equipment etc. then we should go to a grounded source to dissipate any build-up of a static charge.
Now here is where I am seeing some disagreement with some of our fellow electricians. In fact, one stated that you could have about 1,000,000 ohms to ground, because grounding is not important with static electricity.
Now here is where someone needs to educate me, or we need to educate the ones that do not believe that grounding is important with static electricity.
Please pardon me for not letting this alone, because (bonding, grounding) of static electricity is very important, and very dangerous in a hazardous area where you are loading and unloading hazardous materials.
So, with all of that said, I hope that someone will either educate me or we may help others to understand the importance of having static electricity, bonded and grounded.
Thanking you in advance for any of your expertise in this very important subject.
