static electricity seems to trip breaker
Natfuelbilll
Customer swears that a static spark from his fingertip to light switch will cause the branch breaker to trip.
Any experiences on this, or is he over-caffinated?
gar
Ann Arbor, Michigan
EE
090305-1059 EST
Define the breaker. If it is a standard thermal breaker, then no way because there is not enough energy in that spark. If it is an electronic breaker, then it is possible.
charlie b
Lockport, IL
Semi-Retired Electrical Engineer
I don't know whether this would explain it either, but any chance this is an AFCI breaker?
Rewire
This sounds like the story someone posted about the lady who said the breaker tripped when the phone rang which turned out to be a bad recep behind the couch she sat in tripping the breaker when she got up to answer the phone.
sgunsel
That static spark could be up to 10,000 volts or so, AND a couple of microamps. NO way it would trip a circuit breaker.
charlie b
Lockport, IL
OK, my next dumb suggestion: If he were to be wearing rubber soled shoes, so that there is no spark being built up, can touching the switch still trip the breaker? Could be loose wiring inside the switch. Now that I am typing, it also occurs to me to ask if the breaker that trips is the one that serves the light that is controlled by this switch?
sgunsel
Wearing rubber soled shoes will gaurantee that you build up a static charge.
Whatever shoes you wear, discharge any static by touching a grounded object, such as the enclosure first. That will immediately dissipate any static charge. Then you will have to find the real problem, possibly a bad breaker. I'd replace the breaker and see if that fixes the problem.
