Fishn sparky
- Washington State
Good afternoon gents,
New home owner moving into a 2006 built home. Home owner stated that when he touches either switches or receptacles face plate screws, he receives a shock. I went out to see what the issue was. Upon arrival I went upstairs to where the issue is and noticed myself that upon touching the trim screws a small shock occurred. After receiving the shock, I touched the switch again and no shock. Same situation with receptacles upstairs. Steps taken to identify the problem:
I noticed that the upstairs is wall to wall carpet. I was wearing rubber soled slippers when I received the shock. Home owner wearing socks. I went to the main floor to check for the same situation and nothing. Main floor has hardwood flooring in most areas and carpet in family room.
Diagnosis, static discharge? I have been in numerous homes and have not noticed this. Home owner also said it is more prevalent when all fire places are running. These are gas fire places with electronic ignitors. I was unable to turn these on because he was having them serviced and did not want to turn them on.
In your opinion what would be the best way to identify the problem? If static electricity, home owner will receive small shock when touching switches and receptacles upstairs? Really, that can't be.
Thoughts?????
- Went to main panel and pulled off equipment grounds and tested for voltage between EGC's and GEC. No voltage present between.
- Verified GEC is complete and intact.
- Measured voltage at receptacles upstairs. 120V to ground and neutral and no voltage between ground and neutral.
Thoughts?????
