Re: static electricity
I see lightning as being a current source: same current regardless of voltage drop along its path. Once lightning hits something (roof, tree, antenna, whatever), then if there is a high impedance path from that point to planet Earth, there will be a high voltage drop as measured from the point of impact to the dirt. That is a key reason for bonding metal structures, even if they are not at risk of becoming energized from an internal fault of some nearby electrical device. You want a low impedance path for the lightning to follow, so that the structure does not build up a high voltage to earth.
The amount of current should be dependent only on the amount of charge that had built up in the cloud, by the time conditions are right for the discharge to occur.
