Adams14
- Commerce City, CO
I'm intstlling a 9K electric steam generating unit for steam shower in my laundry room, would it have to use a GFI breaker?
I have not run across a steam shower that required a gfci. The unit is not in he shower so I am not sure why they would require it.
Most of us here are not specifying this sort of equipment and are just there to connect it to the power source. Once it is has arrived (no matter who ordered it) the end user don't want to hear, "I won't connect it, it is not listed for use here" and so we either connect it or let them hire someone else to connect it if we still refuse to do so.The units recommended to my clients, which demand Class A GFCI (See #2), are built to comply with the toughest safety certifications, including UL for the United Kingdom, CE for Europe, the tough TUV for Germany and ETL for the USA approval.
No ground fault is needed if the installation-instruction manual either prohibits GFCI / GFI or does not require it, and steam unit has valid NRTL Cert., such as most models listed for North America UL under KQBZ.
However I don't have to recommend those models if I'm more comfortable protecting my clients with Class A GFCI. The tougher TUV standard comes more economically in many cases, and allows me to avoid gambling with counterfeit NRTL labels that void instructions, and overwhelm this equipment space.
Most of us here are not specifying this sort of equipment and are just there to connect it to the power source..
