Steam shower
olly
Berthoud, Colorado
Master Electrician
Does a steam generator for a steam shower require to have a gfci breaker? The unit doesn't need a neutral so I don't even know how I would hook up the GFI if it was required
Probably need to read manufacturers installation instructions to see if gfci required on steam shower. A 2 pole gfci breaker does not require a neutral in circuit to operate. Just be sure and connect white pigtail on breaker to neutral buss. Be sure and consult manufacture’s installation instructions on this device also.
