Excuse me if this is the wrong forum for these questions, but there doesn't appear to be another forum to address installation, techniques, and other industry "best practices" that are independent of the NEC requirements. (Perhaps Mr. Holt or one of the moderators will create such a forum.)
My questions have to do with installation of steel conduit, primarily with regard to fittings. I posted a list of questions yesterday in another self-help Web site (because I wasn't sure where to post my questions here), and I did get one well-informed response. But there are still some unanswered questions, and I'm sure the combined experience an wisdom on this site will quickly resolve them for me. :wink:
1. Regarding compression fittings for joining or connecting EMT, I know there are special raintight, liquidtight, and concrete-tight fittings. But the compression fittings I'm looking at have no specific application listings, neither on the package nor on the fitting itself (nor on the manufacturer's Web site). So does that mean these "regular" compression fittings are only for dry environment use? If so, why would you use one of these compression fittings instead of the set-screw type fittings? Obviously cost must be a factor in this decision. And the gentleman who replied on the other forum did mention that the compression fittings form a tighter, more secure joint (which is why I prefer them). But what are the reasons when you would be compelled (either by code or by "best practices") to use "regular" compression fittings instead of set-screw fittings?
2. Threadless, set-screw type conduit fittings are available as either die-cast zinc or formed steel. Are there specific applications where one type is preferred (or required) versus the other type? It seems to me that steel would always be better as I've seen many die-cast fittings in old work that were split from over-torquing. (I have to wonder if some of the fittings might have split some time after the actual installation due to thermal cycling, accumulated stresses, and/or fatigue.) The gentleman on the other forum stated: "die cast fitting tend to fit tighter on the pipe and are generally preferred in my area." But I'd like to get more feedback on this.
3. I can see the physical difference between an LB conduit body and an SLB Service Entrance Elbow. But besides being able to flush-mount an SLB (and the fact that an SLB is smaller than an equivalently-sized LB), are there any other differences in the use of these two fittings? What is it about the SLB that makes it specific to the service entrance? (Is it because the LB is designed to contain splices and the SLB is not?) Given the choice, would you prefer an LB over an SLB to gain the additional volume for bending wires? Or would you prefer the SLB for the convenience of the flush-mounting (and its lower cost)? Note that for the application where I want to use one of these, the conduit body I select (either SLB or LB) will not contain any splices; I just need it to change direction on the conduit run.
4. What size screw is commonly used to secure one-hole mounting straps for 1/2" and 3/4" EMT? I initially selected #10 sheet metal screws (for attaching to metal framing), but the #10 screw was swimming in the large 1/4" x 5/16" elongated hole that is factory-punched in the mounting strap. Would a #12 or #14 screw be a better choice? The gentleman on the other forum replied that he doesn't generally worry about the sloppy hole and "as long as you can use the screw to tighten the clamp, you are fine." This seems like a perfectly reasonable answer. But I thought I'd throw the question out again here for additional opinions.
Thanks in advance for all replies! :smile:
