1. Can I run PVC conduit underground for the buried section, and extend both ends
above ground using rigid steel conduit?
2. Is it a good idea?
3. I have heard of the exception in the NEC permitting elbows to be steel in an otherwise non-metallic conduit run to avoid abrasion when pulling wire.
PVC can and does fail in heat and exposure. Hence the Q.
