Junior Designer
Hello All,
Can anyone tell me if if the use of steel wire armored cables and cable glands are acceptable for use in Class 1 Div 1 and Zone 1 applications.
I am working on the a boiler supply and installation project and the client has some additional requirements for interconnections between the new boiler and existing control system, the connections are to be made on junction box which is installed on the burner assembly, all vendor supplied instruments are connected to this junction box via rigid metal conduit. The client insists that with an explosion proof gland the use of SWA cable (which they have in their stock, probably from a previous in house project) will satisfy the code requirements. I am not sure that this is correct since the SWA is not a continuous metal sheath and if a cable gland is used directly on the junction box no seal fitting can be installed.
Any help will be appreciated.
