Hello,
We are working on a renovation project where we have a step-down transformer on the 3rd floor of a building. That transformer steps down 480V to 208V and serves a new equipment panel. We called for the secondary neutral to be bonded to the transformer case and the nearest cold water piping. The building code plans reviewer has called for that bond to take place within 5' of where the domestic water pipe enters the building and is quoting 2008 NEC 250.30 (A) (4) (7) (1). Knowing that the reference doesn't exist, I think they are referring to 250.30 (A) (7) (1), which references in itself 250.52 (A) (1) which deals with grounding electrodes. The bonding of the transformer secondary neutral to the nearest cold water pipe was not intended to serve as an electrode, but rather was to satisfy 250.104 (D) (1). The grounding conductor that is ran with the primary conductors to the step-down transformer, which is tied to the transformer case and secondary neutral, would serve as the grounding electrode conductor back to the main grounding electrode.
Should the step-down transformer be bonded to the water pipe within 5' of the building entrance or can it be bonded in the area being served by the transformer, as noted in 250.104 (D) (1)? Thanks for the help!
