Here's the scenario..
120/208v primary - 480v secondary. 30kva step up transformer
I would like to install the transformer next to the Main panel where it will be fed from an 80 amp circuit breaker. The transformer will feed one piece of equipment (outside of the building). Would I be required to install a fused disconnect with in sight of the transformer, or would a fused disconnect next to the equipment I am hooking up be sufficient?
Thanks.
Thanks.
