White Lion
- Quebec
- Electricien
A 120/240V single-phase service is stepped up to 1000 volts for the 1/2 mile run to the shop, then stepped back down to 120/240V with the x0 connected to ground. Now considering only the portion between the two transformers, can someone explain if and why you would need to ground one of the lines? Is there a danger leaving it ungrounded? Does either Canada or USA have an article in the code dealing with this situation?
