Irocelectric93
- Byrnes Mill, MO
Hello everyone, I'm new to the forum but have been on here as a guest in the past. I wasn't exactly sure where to post this and hopefully someone here can at the very least point me in the right direction. I work for a local university and there's a need for a small water heater in the corner of a particular mechanical room. The water heater is a smaller 120v and I was asked to run the electric for said unit. The only 120v panels in the mechanical room are basically at max capacity and are about 140 ft or more (estimate) from where the tank has already been plumbed and mounted my another mechanic or contractor. About 8 or 9 feet from this water heater there is a 480/277 3 phase lighting panel. I've wired a small stepdown transformer in the past but its been more than 4 or 5 years ago when i was still in trade school. My question is this: is it possible to wire a small (say square D) step down transformer to a small load center for the heater? The heater itself draws 25amps....although assuming this was doable i'm not really sure how i'd come off the panel to the transformer itself. This also begs the question which would be preferable... a 480 to 120v or a 277 to 120v transformer? Also not sure as far as protection of the transformer itself (fuses or a breaker from the panel).
