Stereo Floor jack
krisinjersey
Hubbell
Hubbell
I know hubbell makes a line that has brass face plates and the box will accept any plate below it. That way you can use a Leviton Speaker Jack in a Mod plate. The issue with that system is it's primarily used in a concrete floor, and I don't know where you're installing, or if that would work.
charlietuna
Hubbel makes a threaded brass plate (both single or double gang) square or round that a brass pedistle screws into with a plastic insurt to protect the cables. Cable comes out the side of the pedistle.
