gsurace
- Brunswick, OH
- Electrical Contractor & CSA Certification Engineer
I will admit this is a situation that somebody else had questioned me about so much, that I have to make sure I am not missing something. Here is what I have:
A warehouse facility has material they keep stored in a semi trailer parked at one of their loading docks. The material needs to stay chilled so the trailer is equipped with an A/C unit on the front. It is a 230 volt, 3 phase unit that is cord connected. I installed the branch circuit via a couple of buck/boost transformers and local disconnect. The "facilities guy" is insisting that I drive a ground rod to ground the trailer. My response was absolutely not because any fault current should return on the ground wire in the cord. We have to assume that all metal parts of the trailer that could become energized are properly bonded as well.
Not only am I looking for a quick sanity check, if someone can provide a section in the code book as well, that would be fantastic!
