We're going to be replacing the incandescent obstruction lighting on three 55 year old radio towers with new LED obstruction light fixtures. The project will involve stripping out all of the old, brittle, braided-insulation wiring and replacing it with new conductors better suited to the application.
The existing 1" rigid conduit is in remarkably good condition, and we'll be re-using it for the new system. We will be running one #10 and up to four #12's in that conduit, depending on height (there are four levels of lights, and unlike the old installation each level will be wired on a separate conductor to allow remote monitoring of the light status). My issue here is how to best provide vertical support for these conductors. In a new installation, there are special junction boxes designed specifically for tower lighting that have strain relief means built in. In this case, it appears that there was no strain relief used in the original installation, and if there was it wasn't on the construction drawings.
What would be the best means of providing strain relief for these conductors? I've seen strain relief devices like the O-Z/Gedney cable supports that mount to conduit nipples, but I haven't found anything as yet that fits 1" rigid. I'm leary of braided-wire grips when using multiple individual conductors -- seems like it would be easy for one of then to slip loose. I keep thinking I've seen something on the order of a neoprene drive-in plug with holes that is made for just this situation, but I haven't found anything yet.
And, of course, whatever we use has to be easy enough for a guy to work with while hanging from the side of a tower.
Any ideas?
D.
Any ideas?
D.
