Ronnythebull
- Mentor Ohio
My neighbor told me of two issues that I think may be related. I haven't looked at the switch wiring yet, but wanted to do some pre-thinking before I do, in order to save time.
1. She had an electrician change out a garage fluorescent light for a standard LED bulb type because she complained the fluorescent took too long to turn on, even on warm days. But, the LED takes about 3 seconds to come on:huh:, so I'm thinking the problem is not with the lamp or fixture.
2. She said she also noticed the fluorescent light in the laundry room (garage and laundry room are next to each other so I'm assuming they are on the same circuit), when the switch is off, still shows some dim light from the bulbs:huh:.
I'm thinking these 2 things are somehow related, but I can't figure it out. Could it be that the laundry room fluorescent bulbs need to heat up before the garage light comes on? I can't figure out how that could have been mis-wired that way, but it's the only thing I can think of.
I'm going to take a gauss reading as my first investigative tool, knowing that the garage light is on a 3-way and I want to know if the original installer used 2-wire Romex for the travelers to save on the cost of 3-wire. This would require "borrowing" a neutral from a source near one of the 3-ways. Not sure how this could cause the issues with the lights, but I'm curious.
If I can't think of a solution ahead of time, I'll just start opening up switch boxes and trace the problem manually.
Has anyone ever heard of these issues, and does anyone have any suggestions?
Thanks in advance.
Ron
Thanks in advance.
Ron
