tjacobs
- Moorestown, NJ
Got a call about a clothes dryer not making heat. Went to the house and this is what happened. I started the dryer and the drum was rotating but no heat. Pulled the 4" vent duct off and it was blowing strong. I figured a bad heat element. The customer had already bought a brand new dryer and had it sitting there. I hooked up the new dryer and same thing. I pulled the breaker panel cover and got my meter out. I put my meter leads on each pole of the breaker and read zero volts. Meanwhile the dryer is still running and blowing cold air. I thought I was seeing things. Took my meter leads and went from each pole of the breaker to the neutral bar and had 120 volts on each pole. I replaced the breaker and the dryer worked perfect ( making heat ). Has anyone ever had a breaker do this? 120 from each pole but zero between poles instead of 240 volts. Very strange.
