kevinengineer99
- usa
- engineer
If I have a 6 story building with 8 set of panels on each floor, how would you feed them?
Do you use bus duct? I was told you'd need people in field measuring dimensions and there'd be longer lead times and expensive due to supply shortage.
Do you use one large feeder and sub-feed panels on each floor? Seems like if you had to work on a panel, you'd have to do it hot or shut down all panels on the same feeder.
Do you use individual feeders from a distribution board? It would require most feeders to go between floors.
