Hey guys, I have a stray voltage scenario that you might find interesting. I’m getting between 5V to 20V on a thermostat cable to an air handler. I removed the cable from system completely (AH, HP, and tstat) and still had that voltage.
I also have same voltage on the ground of the branch circuit coming in even with the power disconnected.
There is an excessive amount of bundling of romex cables on the ground level. This is a clubhouse with maybe 40-50 golf cart chargers running where these cables are bundled as well. Well over 12-15 12/2 and 12/3 cables bundled with the 6/2 romex I’m testing.
Only solution I can find is to pull a new circuit and new tstat cable. Any suggestions?
