Hello, we recently had a ground fault on a 480 3 ph ungrounded delta system. As you know that means that one phase (the grounded one) will read zero when measured to ground. But what we found while looking for the ground has me confused. There is and old abandoned 15"chase with three pipes in it none are conduits and they are cut of at both ends it is about 70 ft long buried 4 ft in the ground. It was discovered that the chase and all of the pipes when measured to either the earth or to building steel or piping that we recorded 240 volts. After the fault was cleared the pipe chase also cleared of any voltage. There are no underground conduits in the vicinity of the chase. Anyone have any thoughts on how this pipe chase became energized?:?
