doug glasscock
 - Virginia
I have a light switch that is fed by a 15amp breaker. The hot, neutral and ground at the light switch ceiling box are skinned back and not connected yet. With the light switch "OFF" I get 30VAC from Hot-Neutral at the ceiling box. With the light switch "ON" I get 120VAC from Hot-Neutral at the ceiling box.
Is this normal, loose connection somewhere or what??
