ce2two
- where it rarely rains .
ever had to find a direct short in underground I.M.C or the it's equal ,turn on the breaker that feeds 15 street lights ,the breaker growels for about three seconds then trips..pull load wire from breaker attach to a 120vac. light bulb, 120watt ,other side of lt to the breaker ...divide 120 into 120 u get 1 amp,go pull box to pull box till the time ,u find a current reading other than 1 amp then u will have found your problem...............it realy works think before you jump in the water...........
