I purchased a new home back in 2013, located in a gated community in Indian River County. The street lights were installed by an electrical contractor several years ago. The Builder is still selling homes here trying to close out the project. The problem is that it is costing the HOA 6K each year to repair and maintain the street lights. They are off more that they are on! I spoke to the EC who is the only contractor that will work on the lighting system. He has stated that some of the wiring was found to be burned up, and fixture ballasts are over heating and failing. As it turns out there is NO overcurrent protection on the lighting feeders and are fed from multiple sources from FP&L transformers. The HOA is being charged a flat fee from FP&L for the operation of the street lights. I have looked for and did not find any supplemental protection for the street light feeders or for the branch circuit wiring going to the fixtures. I opened three hand holes located at the base of the pole. I found that there is only two feeders (120 volt phase conductor and a neutral) direct buried single conductor cable. There is no fusing at the base and standard wire nuts connecting an aluminum wire to a copper wire. I also noticed that (this is great) no EGC installed either with the feeders or the branch circuit wiring to the fixture.! The contractor installed two single conductor aluminum feeders to service the street lights. I think the AWG is No. 8 or # 6.
I went to the building department to review the drawings on file, which there were none on file;l nor was any inspection permits for the street lights were on file.
Question, In a gated HOA community what design standards (including the NEC) should be used to design the street light system? Should this be a requirement of the County to adopt standards?
This installation is chock filled with NEC violations! Also a potential Hazard !
Any assistance or guidance will be appreciated.
