electro7
- Northern CA, US
- Electrician, Solar and Electrical Contractor
Couple questions regarding standard string inverters:
1. Is it true that if one module is shaded it brings down the other modules in that series circuit to the power output of the shaded module? I feel like I am going back to kindergarten about this issue since doing so much with optimizers these days. Do the bypass diodes in the modules allow for the current to flow through and not cause the power output of the rest of the modules in that series to decrease with shading on the string?
2. I have heard, and have done it many times, that oversizing the PV to the inverter is better. I heard from one manufacturer that the inverters are made to work that way and is therefore better for the longevity of the inverters. I understand that modules would rarely hit the stc rating of the modules so maybe oversizing some is okay. But I have had big clipping on Solaredge inverters when I have oversized those in the past, with groundmount arrays facing the same direction. Then I have heard you get more on the shoulders of the IV curve (morning and night) and it far makes up for the clipping that could happen in peak summer time.
So my question here is with standard string inverters, no optimizers, is it better to oversize the PV to the inverter and if so what is the best ratio? And why is that the best ratio? Economics aside.
Thanks!
Sent from my SM-N960U using Tapatalk
Thanks!
