DEW202001
- ODENTON, MD
What do you think.
I think there is little info here.
Seen a few of those, have you? :blink:Those look like busted conductors like when a backhoe digs them up.
That does not appear to be recent damage based on the color of the exposed copper. Were the conductors tested before the VFD was hooked up? Were the conductors in use prior to the connection of the VFD?
Looks like a certain kind of automatic stripper was used on all but rightmost wire.... the kind that constricts the wire in a hole (two half holes squeezed onto insulation) then grips and rips the insulation off the end.The stripped end looks funny, almost like the wires stretched and broke when pulling in or out!
Looks that way to me too.The stripped end looks funny, almost like the wires stretched and broke when pulling in or out!
I agree, that's the first thing I thought of seeing that.The stripped end looks funny, almost like the wires stretched and broke when pulling in or out!
But I still don't see it as recent damage. I really doubt the conductors were tested prior to the connection of the VFD.I agree, that's the first thing I thought of seeing that.
My guess:
Someone dug up a conduit with a backhoe and bent it. That made the conductors pull out of one end or the other. So even after they straightened out the conduit and reburied it so that nobody would notice, they had to pull the conductors back out of it to re-make that connection. In pulling them back through the now crushed conduit, they stretched, then snapped the conductors.
It fits that "troubleshooting flow chart" joke, where it says "Did anyone see it yet?" => No => "Hide it". This will be followed by "Does anyone know it was you?" => No => "Blame someone else!"
What was in the conduit? I just do see that a recent damage unless there is something corrosive involved? Is this at a sewage treatment plant? H2S will turn copper black very quickly?No they where tested. I witnessed the Meg test and have the Meg sheet.
If those were in a pipe how could they pass a meg test? I've seen frost break wires like that, looked like they were pulled apart. I've seen excavators make wire look like that also. They look like they've been broken for awhile but if they were submerged for a long time the wire could be oxidized like that the whole length of the run.
Someone pulled the wire out, stripped off an inch of insulation, then pulled them back in again? For what purpose, sabotage to cause an explosion? That would make this a serious criminal investigation! Malicious mischief? Seems like an awful lot of effort to do that just to mess with someone. The accidental aspect an cover up seems a lot more plausible to me.the contractor thinks someone went back and stripped inch of the insulation off to expose the copper. When he pulled the conduit out the wires broke off.
