I have a situation where a strobe warning light was installed with an integral motion sensor/relay/time delay feature. Normally, when anyone passes this motion sensor, the strobe activates and pulses, for a short time delay (10 seconds) and then shuts off.
At times the strobe is activated, but will continue to stay lit as if stuck in the delay mode. It is wired to 1 hot of a 3 hot/1 neutral circuit with a coffee machine on one circuit and computers on the other 2 circuits.
Could not having a separate neutral for the strobe cause the light to stay on, by locking the relay closed, or has anyone ever had a problem with something like this before?
(The light has been tested on a dedicated circuit and always operates properly--only stays on too long when wired in to the multi-wire circuit)
Thanks for any help.....
