Stub up in footings
CubpME52
Texas
Has anyone stubbed up through a building footing or building column footing. On a project where they are allowing it. I've always been told to stay away from them
I don't see it as a problem as long as it is approved by the structural engineer.
I agree. If the engineer approves it I wouldn't worry about it. It's not the sparkys job to decide if the conduit will result in a structural defect.
Any slab on grade will have conduits and dwv piping through the footing.
Ive brought them up through footings before.
I would avoid column footings though. Not sure if that’s a code issue.
